by julien1486 » Mon Dec 06, 2010 2:22 am
Hello !
I'm using a CheckBoxTree and I need to store the CheckBoxTreeSelectionModel in order to restore it later if the user cancel his change.
I was looking for a method like setCheckBoxTreeSelectionModel() but this method does not exist. Is there a reason for this ?
Thanks a lot for your answer,
Julien
julien1486
by JIDE Support » Mon Dec 06, 2010 12:51 pm
It's just the design without specific reason. As a workaround, you could invoke CheckBoxTreeSelectionModel#getSelectionPaths[] and set it back to restore the selections.
