Problem with StyledLabel in MacOSX
Postby Caires10 » Mon Oct 04, 2010 2:02 am
I'm having the following problem. When I run my application on MACOSX this doesn't start and does not throw an exception. I already made debugging and the problem is in the creation of a StyledLabel (new StyledLabel ())
Anyone know if the creation of this object, in MACOSX, can bring some kind of problem?
Best regards
Caires10
Re: Problem with StyledLabel in MacOSX
Postby JIDE Support » Mon Oct 04, 2010 8:56 am
We tested on Mac OS X so StyleLabel should be the problem. Could you please make a simple test case for it?
Postby Caires10 » Mon Oct 04, 2010 10:30 am
Ok, i'll make that test case and post here
Best regards
Caires10
Postby Caires10 » Wed Oct 06, 2010 7:31 am
While doing the test case, I noticed that the problem is not really the StyledLabel but the combination of the StyledLabel and a Look&Feel that I created. In that test case (which did not have my L&F), the StyledLabel it's rendered as well as in my application.
Anyway, when my L&F is used in the test case, I got the following exception:
Exception in thread "AWT-EventQueue-0" java.lang.NullPointerException
at javax.swing.plaf.ColorUIResource.<init>(ColorUIResource.java:47)
at com.jidesoft.plaf.vsnet.VsnetMetalUtils.initComponentDefaults(Unknown Source)
at com.jidesoft.plaf.LookAndFeelFactory.installJideExtension(Unknown Source)
at labeldemo.LabelDemo$1.run(LabelDemo.java:74)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:633)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:296)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:211)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:201)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:196)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:188)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:122)
Anyone knows what might be causing the problem? I have to fill some of the properties of L&F?
Best regards.
Caires10
Postby JIDE Support » Wed Oct 06, 2010 9:19 am
Yes, the related properties are listed below. Please try to fill the "textHighlight" property in your L&F.
Postby Caires10 » Wed Oct 06, 2010 9:35 am
Ok i'll try that and then I'll give some feedback.
Thanks for all the support.
Best regards
Caires10
Users browsing this forum: No registered users and 153 guests
