JideTabbedPane with ECLIPSE3X shape
Postby trungmtran » Wed Sep 29, 2010 4:39 pm
I am trying to set the JideTabbedPane shape to SHAPE_ECLIPSE3X, but it keep showing the SHAPE_OFFICE2003. I tested on both Window Vista and Ubuntu, SHAPE_ECLIPSE3x seems not able to display. Any Idea?
trungmtran
Re: JideTabbedPane with ECLIPSE3X shape
Postby JIDE Support » Wed Sep 29, 2010 5:11 pm
Please try the following code and see if it works.
                            LookAndFeelFactory.installJideExtension(LookAndFeelFactory.ECLIPSE3X_STYLE);
                            _tabbedPane.setTabShape(JideTabbedPane.SHAPE_ECLIPSE3X);
                            _tabbedPane.setColorTheme(JideTabbedPane.COLOR_THEME_WIN2K);
Postby trungmtran » Thu Sep 30, 2010 11:38 am
Using your suggestion, I got NPE as shown below, Do i need to install or set something before using LookandFeelFactory.
Exception in thread "AWT-EventQueue-0" java.lang.NullPointerException
at com.jidesoft.swing.FastGradientPainter.createGradientTile(FastGradientPainter.java:84)
at com.jidesoft.swing.FastGradientPainter.drawGradient(FastGradientPainter.java:47)
at com.jidesoft.swing.JideSwingUtilities.fillGradient(JideSwingUtilities.java:2405)
at com.jidesoft.plaf.eclipse.Eclipse3xJideTabbedPaneUI.paintTabBackground(Eclipse3xJideTabbedPaneUI.java:734)
at com.jidesoft.plaf.basic.BasicJideTabbedPaneUI.paintTab(BasicJideTabbedPaneUI.java:928)
at com.jidesoft.plaf.eclipse.Eclipse3xJideTabbedPaneUI.paintTabArea(Eclipse3xJideTabbedPaneUI.java:204)
at com.jidesoft.plaf.basic.BasicJideTabbedPaneUI$ScrollableTabPanel.paintComponent(BasicJideTabbedPaneUI.java:7877)
at javax.swing.JComponent.paint(Unknown Source)
at javax.swing.JComponent.paintChildren(Unknown Source)
at javax.swing.JViewport.paint(Unknown Source)
at javax.swing.JSplitPane.paintChildren(Unknown Source)
at javax.swing.JLayeredPane.paint(Unknown Source)
at javax.swing.JComponent.paintToOffscreen(Unknown Source)
at javax.swing.RepaintManager$PaintManager.paintDoubleBuffered(Unknown Source)
at javax.swing.RepaintManager$PaintManager.paint(Unknown Source)
at javax.swing.RepaintManager.paint(Unknown Source)
at java.awt.GraphicsCallback$PaintCallback.run(Unknown Source)
at sun.awt.SunGraphicsCallback.runOneComponent(Unknown Source)
at sun.awt.SunGraphicsCallback.runComponents(Unknown Source)
at java.awt.Container.paint(Unknown Source)
at javax.swing.RepaintManager.paintDirtyRegions(Unknown Source)
at javax.swing.RepaintManager.seqPaintDirtyRegions(Unknown Source)
at javax.swing.SystemEventQueueUtilities$ComponentWorkRequest.run(Unknown Source)
at java.awt.event.InvocationEvent.dispatch(Unknown Source)
at java.awt.EventQueue.dispatchEvent(Unknown Source)
at java.awt.EventDispatchThread.pumpOneEventForFilters(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source)
at java.awt.EventDispatchThread.pumpEvents(Unknown Source)
at java.awt.EventDispatchThread.run(Unknown Source)
at javax.swing.JComponent._paintImmediately(Unknown Source)
at javax.swing.JComponent.paintImmediately(Unknown Source)
trungmtran
Postby JIDE Support » Thu Sep 30, 2010 11:44 am
Looks like JIDE extension is not correctly installed. The key "DockableFrame.activeTitleBackground" in UIDefaults does not contain a valid value. Please check out JIDE JideTabbedPaneDemo FYI. In that demo, you could switch the style freely.
JideTabbedPaneDemo.java
(30.5 KiB) Downloaded 2148 times
