Stop search event firing from SearchableBar
Postby anujaj » Wed Sep 29, 2010 8:30 am
I have a SearchableBar (associated with code editor) each in one tab of tabbed pane.
The search text of the bar from current pane should be shown by default, in the search bar of any other tab when enabled/changed.
I have implemented the same by storing the getSearchingText() under this listener
searchable.addSearchableListener(new SearchableListener () {
public void serachableEventFired(SearchableEvent arg0) {
searchStr = searchableBar.getSearchingText(); } });
and then setting the same text in
tabbedPane.addChangeListener(new ChangeListener() {
public void stateChanged(ChangedEvent e) {
searchable.setSearchingText(searchStr); }});
Though the search string got from last tab is correctly displayed in the new tab,
somehow the search event is simultaneously fired also in the new selected tab.
Can this search event firing be controlled (in fact, stopped)
and only the search text appears in the new tab, so that actual search
does not happen by itself but only when user wishes to do so.
Any help in this direction is appreciated.
anujaj
Re: Stop search event firing from SearchableBar
Postby JIDE Support » Wed Sep 29, 2010 9:22 am
Please remove the document listeners of the JTextField#getDocument() inside SearchableBar before you invoke setSearchingText() then add those document listeners back thereafter. You could get the instance of the JTextField by overriding SearchableBar#setSearchingText(). In this case, you will not get the Searchable event fired. However, you will not get the Searchable work as well.
Users browsing this forum: No registered users and 10 guests
