Checkboxtree unchecked selections
Postby soniks » Fri Sep 03, 2010 2:07 am
I am using the Checkboxtree with digin=true which selects all lower level nodes too and returns the top level node as the selected node only. However when you deselect any of the lower level nodes the list of selected nodes changes to include all the lower level nodes. Is it possible to have the tree control give you the top level node and a list of excluded nodes instead?
Regards
soniks
Re: Checkboxtree unchecked selections
Postby JIDE Support » Fri Sep 03, 2010 6:56 am
I'm afraid not. You may create your customized CheckBoxTreeSelectionModel to do so.
Postby soniks » Fri Sep 03, 2010 8:25 am
Thanks do you have any tips on what needs to be changed to do this.
soniks
Postby JIDE Support » Fri Sep 03, 2010 9:21 am
I believe you need first define how you would like to store the tree path selections in your selection model. For example, if nothing is selected, the excluded path will be stored as the root path only or all the leaf tree paths. So you probably also need a isDigIn flag there. After the specification is defined, you'll be able to evaluate the work load. From my point of view, it's not easy to do so reversely.
