Checkboxtree disabling nodes
Postby soniks » Thu Aug 12, 2010 3:10 pm
I have created a tree with digin attribute set to true and would like to disable the check box for any child nodes (upto leaf node) of the selected nodes. Is this possible and how would this be done? I looked at some previous posts and there was mention of overriding the isCheckBoxVisible which will in effect stop the users from deselecting the child nodes but I would rather prefer the checkbox shown checked and not editable. Obviously it would be enabled only if the parent node was deselected.
Regards
soniks
Re: Checkboxtree disabling nodes
Postby JIDE Support » Thu Aug 12, 2010 3:13 pm
Please give 2.9.5 a try. In that release, overriding CheckBoxTree#isCheckBoxEnabled(TreePath) would fulfill your request.
Postby soniks » Thu Aug 12, 2010 3:50 pm
Thanks for the quick response - do you know if it is available on any remote maven repositories yet? I can't seem to download it from java.net -m2 repository.
soniks
Postby JIDE Support » Thu Aug 12, 2010 3:52 pm
We don't support maven yet although it is in our job list.
Postby soniks » Thu Aug 12, 2010 4:14 pm
Thats strange I downloaded 2.9.4 from the repository mentioned before. Is that repository not maintained by Jide? I noticed 2.9.4 already has the isCheckboxEnabled(TreePath[] treepaths) method. Isn't it the same thing or have there been changes in how it is used?
soniks
Postby JIDE Support » Thu Aug 12, 2010 4:16 pm
There was a regression and we just fixed to make it work again in 2.9.5.
