Calculator - too many calcs
Postby newmanj » Sun Aug 08, 2010 8:26 pm
I'm having some issues with the way the Calculator class operates. It's a bit difficult to explain, but I'll try to make it clear in an example. Pressing the following sequence of instructions leads to an extra, unwanted calculation taking place...
6 + 2 = *
The "6+2=" part operates as expected and produces the result 8, but then when the multiply button (or any other operator) is pressed, it performs another calculation, adding 2 to 8, producing the result 10. I would expect that instead of performing this operation, the 8 would be used as the primary operator in the next (multiply) calculation. Is this a known feature of the calculator? Is there an easy fix?
Thanks!
newmanj
Re: Calculator - too many calcs
Postby JIDE Support » Mon Aug 09, 2010 11:49 am
Thanks for bug report. Will fix it in 2.10.0. Have checked the fix in the open source project. You could get it to build your own jar if you cannot wait.
Postby JIDE Support » Mon Oct 04, 2010 1:29 pm
Just so you know, this is fixed in 2.10.0 just released.
Users browsing this forum: No registered users and 250 guests
