CheckBoxTree: SELECTED, DONT_CARE look same when disabled
Postby Sbodd3 » Tue Aug 03, 2010 7:01 am
So, I have a CheckBoxTree that's read-only (I want to display heirarchical selections, and allow the user to expand/collapse the tree but not change the checked state of items in the tree). My problem is that, when I do this, the "some-elements-selected" and "all-elements-selected" checkboxes look the same. (Using the default Swing look-and-feel on either Windows or Linux)
CheckBoxTree tree = new CheckBoxTree(model);
tree.setCheckBoxEnabled(false);
I was able to work around this by extending CheckBoxTree, and overriding createCellRenderer to create a custom subclass of CheckBoxTreeCellRenderer with an overridden getTreeCellRendererComponent() method (see below). In my override, I skip the call to _checkBox.setEnabled(enabled).
I have two questions:
1) Is there a better way to do this? This seems like it's embedding an awful lot of the implementation of CheckBoxTree in my code.
2) Are there any oddball side effects of not disabling the checkbox that I should look out for? I haven't found any yet.
Thanks!
    public Component getTreeCellRendererComponent(JTree tree, Object value, boolean selected, boolean expanded, boolean leaf, int row, boolean hasFocus) {
        _checkBox.setPreferredSize(new Dimension(_protoType.getPreferredSize().width, 0));
        _emptyBox.setPreferredSize(new Dimension(_protoType.getPreferredSize().width, 0));
        applyComponentOrientation(tree.getComponentOrientation());
        TreePath path = tree.getPathForRow(row);
        if (path != null && tree instanceof CheckBoxTree) {
            CheckBoxTreeSelectionModel selectionModel = ((CheckBoxTree) tree).getCheckBoxTreeSelectionModel();
            if (selectionModel != null) {
                boolean enabled = tree.isEnabled() && ((CheckBoxTree) tree).isCheckBoxEnabled() && ((CheckBoxTree) tree).isCheckBoxEnabled(path);
                if (!enabled && !selected) {
                    if (getBackground() != null) {
                        setForeground(getBackground().darker());
                //_checkBox.setEnabled(enabled);  //COMMENTING OUT THIS LINE is the significant change
                updateCheckBoxState(_checkBox, path, selectionModel);
        if (_actualTreeRenderer != null) {
            JComponent treeCellRendererComponent = (JComponent) _actualTreeRenderer.getTreeCellRendererComponent(tree, value, selected, expanded, leaf, row, hasFocus);
            Border border = treeCellRendererComponent.getBorder();
            setBorder(border);
            treeCellRendererComponent.setBorder(BorderFactory.createEmptyBorder());
            if (path == null || !(tree instanceof CheckBoxTree) || ((CheckBoxTree) tree).isCheckBoxVisible(path)) {
                remove(_emptyBox);
                add(_checkBox, BorderLayout.BEFORE_LINE_BEGINS);
            else {
                remove(_checkBox);
                add(_emptyBox, BorderLayout.AFTER_LINE_ENDS); // expand the tree node size to be the same as the one with check box.
            add(treeCellRendererComponent);
        return this;
Sbodd3
Re: CheckBoxTree: SELECTED, DONT_CARE look same when disable
Postby JIDE Support » Tue Aug 03, 2010 9:33 am
Your solution is fine for me. I'm afraid there is no better solution for now. The painting is controlled by the button model of the JCheckBox, armed, pressed, selected. So the difference could only be visually obvious when the check box is enabled.
