How do I tick a checkboxtree from within an application
Postby neverton » Sat Jul 24, 2010 2:48 pm
I've probably looked at the answer several times, but it's been a long day and my brain is starting to bubble out of my ears now :shock:
I've just started using the JIDE community library today, after having tried the Ansir tristate library for an application, but the Ansir has too many 'quirks' that I can't use it within my application.
I've converted my Jtree to use the CheckBoxTree from within the JIDE libraries and the Jtree is displaying as expected, the only thing I cannot see if how I 'tick' a node as I build the tree? I keep a seperate Hashmap of values so I can track which items have been selected on the tree (basically they're all set to not ticked and when I select save it does a;
TreePath[] treePaths = checkboxTree.getCheckBoxTreeSelectionModel().getSelectionPaths();
and for all the matches it sets the HashMap corresponding values to ticked.
So all I want to do, is as I am building the JTree when a user goes back onto the pane, is be able to 'tick' certain nodes if they where selected previously. In the Ansir library I simply did;
DefaultMutableTreeNode node = new DefaultMutableTreeNode(description);
node.setState(Tristate.SELECTED);
for every node I wanted ticked.
Is there something similar in the JIDE to perform the same thing? as it's a very useful feature :)
Regards
Neil
neverton
Re: How do I tick a checkboxtree from within an application
Postby JIDE Support » Sat Jul 24, 2010 7:23 pm
I am not sure if I understand the question. Can you use checkboxTree.getCheckBoxTreeSelectionModel().addSelectionPath or setSelectionPath to pre-"tick" the check boxes?
Postby neverton » Sun Jul 25, 2010 1:34 am
I basically want to be able to tick specific nodes as I build the checkboxTree.
In my old library I simply did;
rootNode.add(node);
and this added the node to the tree with the checkbox ticked.
I did have a look at addSelectionPath yesterday, but to be honest, my Java skills are not brilliant and I wasn't sure how I got a node converted so it would work with addSelectionPath, as I'm sure addSelectionPath wants a TreePath and my node is DefaultMutableNode.
Regards
Neil
neverton
Postby neverton » Sun Jul 25, 2010 4:07 am
No worries, finally got it sorted, sleep does have its uses!!
I run this loop for each of the nodes under root, then if it passes the tests it uses addSelectionPath as you recommended;
    e = legalGrpNode.preorderEnumeration();
    while(e.hasMoreElements()){
        DefaultMutableTreeNode dmtn = (DefaultMutableTreeNode) e.nextElement();
        TreeNode [] ptr = dmtn.getPath();
        TreePath path = new TreePath(ptr);
        tmpNum = Utils.getBracketedNumber(path.toString());
        if (tmpNum > 0) {
            Integer checked = Integer.parseInt(consolLegalGrpMap.get(tmpNum).toString());
            if (checked != null && checked > 0) {
                checkboxTree.getCheckBoxTreeSelectionModel().addSelectionPath(path);
public TreePath getPath(TreeNode node) {
    List list = new ArrayList();
// Add all nodes to list
    while (node != null) {
        list.add(node);
        node = node.getParent();
    Collections.reverse(list);
// Convert array of nodes to TreePath
    return new TreePath(list.toArray());
Regards
Neil
neverton
