how to insert a node to existing check box tree
Re: how to insert a node to existing check box tree
Postby JIDE Support » Mon Apr 19, 2010 10:11 am
Will fix the issue while digIn is false in 2.8.7 and 2.9.0. I could not notice the first issue with your test case. I tried your test case with digIn as false or true, with the table model listener moved or not. Please let me know how I could reproduce the issue if you still notice this issue.
Postby vibhor » Tue Apr 20, 2010 6:48 am
Can u suggest some work around for the second issue mentioned ? I wil get back to you on the first issue in some time.
Vibhor
vibhor
Postby JIDE Support » Tue Apr 20, 2010 6:56 am
I'm afraid not since the fix is to invoke super while isDigIn() returns false.
Postby JIDE Support » Wed Apr 21, 2010 11:05 am
Just so you know, this is fixed in 2.9.0 just released.
Postby JIDE Support » Fri May 21, 2010 10:33 am
Just so you know, this is also fixed in 2.8.7 just released.
Postby vibhor » Mon Oct 11, 2010 9:37 pm
I changed to JIDE 2.9.0 currently . However , the method getMixedContent() in the Element class is no longer available. Is this method changed to getContent() ? Will i need to make any other changes for using this method ?
Vibhor
vibhor
Postby JIDE Support » Tue Oct 12, 2010 9:16 am
I don't think it's JIDE project that provides Element class. It is probably a class in jdom library which has nothing to do with JIDE. Please look for an answer in their change log.
Previous
Users browsing this forum: No registered users and 139 guests
